David,
Why not use datasockets? Using TCP/IP, you will have to come up with
protocol to transfer commands & data from your client to server and back.
Why should you worry about collisions in your app, the underlying
protocol takes care of that.
vishi
davidLee wrote:
> Hello,
> I use TCP/IP as the way of communication between processes ,I'd like
> to know :1,To keep on a stable interact between client and host , what
> time interval could be the preferred ? 2,Due to take on multi thread
> mechanism in my application , I find when experienced a period of time
> (about 6 hours) ,my TCP server application can be killed without
> execuating any quit instruction , I do not know what bug can cause
> such a problem , because there is no any system error prompt .Pl
ease
> suggest a policy to monitor the bug .3,Does CVi support "Volatile "
> keyword ? 4, When the host(TCP server) transmitting data to the client
> ,can I send back data to the host at the same time ? I am afraid that
> if there would be a collision of transmitting .
> David
