Successfully established the connection between server and client but if I continuously send the command from client to server , client application crashes.
To understand what may be happening it could be useful to know how much data are you sending to the server, how often and in which way. Also, do you receive any error?
Thanks , but not related to the previous post. If I send the data from client to server continuously it crashes but if I send the data from server to client no issue.
You must add some detail more to describe the situation. I already wrote some questions that still are to be answered, to which you may add the following:
How much time does the application run before the crash? Is it consistent or varies randomly?
Is it doing something else?
Which fuction are you using to send data? How are data formatted into the message?
Can you post the offending code, highlighting where the crash occurr?
