03-11-2016 09:20 AM
The link worked. However even if I put c:\Program Files (x86)\National Instruments\CVI2015\include and c:\Program Files (x86)\National Instruments\CVI2015\toolslib in the Instrument Directories under Instrument\Search Directories I still get multiple error like:
fatal error: cannot open file '\\us.lmco.com\mst-bot\DocCtrl\4X Manufacturing\48 TE & Tooling Software Files\48-000122\48-000122-001-P01\LabWindows\toolbox.h': No such file or directory
and
fatal error: cannot open file '\\us.lmco.com\mst-bot\DocCtrl\4X Manufacturing\48 TE & Tooling Software Files\48-000109\48-000109-003-P02\analysis.h': No such file or directory
03-11-2016 09:24 AM
As a test, I went to the file that had the error, right-clicked on toolbox.h, did an "open quoted text", and CVI opened the toolbox.h file without a problem. So it can find the files, but not during compiling.
03-14-2016 04:54 PM
I have found the issue. When you copy a project on a network drive and open CVI all the paths are wrong. I have a network drive \\us.lmco.com\mst-bot that is mapped to a local drive letter S:. CVI copies the files and changes to path to network path name, not to the local drive letter. If I change all the files in the project to S:, CVI works.
It looks like CVI can't handle \us.lmco.com\mst-bot\ in the path.
\\us.lmco.com\mst-bot\DocCtrl\4X Manufacturing\48 TE & Tooling Software Files\48-000108\48-000108-003-P01\base.c
s:\DocCtrl\4X Manufacturing\48 TE & Tooling Software Files\48-000108\48-000108-003-P01\base.c
03-14-2016 04:54 PM
Hi Paul_Knight,
At any point, have you tried copy the contents (including both source code and dependencies) of your project over to a new project file with a different name?
03-15-2016 08:56 AM
Yes, the results are the same.
This morning I found something funny. There are two ways for me to get to the network drives. One via a short cut on my desktop that is mapped to the S: drive, the other via My Computer\Network Location.
If I open the project by going to the DocCtrl directory via the short cut, all the network files have s:\ in their path. If I open the project by going to the DocCtrl directory via My Copmuter, all the network files have \\us.lmco.com\bot-net\ in their path. Nothing in the project was changed, just how I got to the prj file.
The first way works, everything complies without an error. The second way fails, can't find files.
03-17-2016 11:39 AM
Hi Paul_Knight,
Thank you for passing along this information! It seems as though we are dealing with a potential bug, or at least some unexpected behavior in how LabWindows/CVI handles network file paths. I will file a Corrective Action Report with R&D, so that they can look into it in more detail. I'm glad that you have been able to establish a workaround in the time being!
04-06-2016 07:18 AM - edited 04-06-2016 07:29 AM
Hi Tommy,
I can confirm issue with network path conflict.
I made project on test PC in CVI2013 (worked fine) and actually upgrated to CVI2015. As soon I open project from loading form of CVI on network PC it opens path like \\new-test-pc\\cvi programms\\fkt .. and by compilation I get several failures of standart libraries looking where compiler search for them in local project folders and bring failure "No such a file or directory".
(f.e: 1, 1 fatal error: cannot open file '\\new-fkt-pc\c\CVI Programs\Hameg HMO\userint.h': No such file or directory)
By opening project by click from mapped drive I get instead of project path to network PC mapped drive letter like Z:\cvi programms\fkt and compiler work fine ...
Thank you for help.
Radovan Demko
04-06-2016 07:58 AM
Radovan
Thanks for confirming the error. I thought it might be something with the way our network was setup. If that was the case, then the error would never get fixed by my network folks.
At least this way, it is something in the complier and NI has a better track record of fixing things than my IT group.
Paul
07-21-2016 02:31 AM
Is there any solution for this problem ? Is there any conformed procedure how to properly setup Remote Debugger in CVI 2015 ? coz standard is working only by special constalation of stars and moon .....
Thank you
07-21-2016 07:16 AM
Yes, my solution or workaround is to use the Windows mapped directory name in the project file instead of using the network directory name. Even though they point to the same place on the network, LabWindows likes the first but not the second.
Basically I have a network mapped directory call S:. It is map to \\server.com\docctrl. So in the project file the file paths are s:\tests\test.c. Sometimes LabWindows will rename the file paths to \\server.com\docctrl\tests\test.c. When it does this, the standard include files are not found.
Paul
