02-08-2010 08:02 AM
I'm using the test version of CVI 2009 and have a problem with the sql toolkit which works fine under CVI 8.5.
DBNewConnection() returns always -100 and the error message is NULL.
Did you have any ideas what causes this problem and how it can be solved?
Thanks in advance
Inomed1
02-15-2010 04:53 AM
Hello Inomed1
have you tried to reinstall the SQL Toolkit? I found some cases in the past where this has been helpful.
For further investigation it would be interesing witch DBMS is used?
Regards
Moritz M.
04-26-2013 10:00 PM
I have the same problem,Is there anybody have the right solution?As same time,I create a new project to test DBNewconnection.It can work. Is the old project referance something that raise the problem?
