11-17-2015 10:28 AM
Hi
I'm wondering what's the simplest way to draw a vertical line? Could you give me an example?
Solved! Go to Solution.
11-17-2015 12:41 PM
If you want to plot the vertical line directly on a panel then you can chose either a splitter control or a transparent canvas with a vertical line (for drawing on a graph you can use PlotLine ()).
The question is if you want to do this interactively in the UI editor or programmatically.
11-17-2015 12:47 PM
Thanks for the info, I would like to UI editor, currently I used splitter to draw a horizontal line, how to draw a vertical line
using splitter?
11-17-2015 12:53 PM
Ah, when selecting the control chose the vertical one
11-17-2015 01:13 PM
Now I see it. Thank you!
