OK, assuming you have two threads thread A and B, and a global variable between them VAR. There are two possible ways to interpret what you want. Either you want:
1) Thread B to wait (block) until thread A sets the value of VAR. Then thread B does something, sets the value of VAR, while thread A is waiting (blocked). When B sets VAR, it goes back to waiting, while thread A runs and sets VAR.
or
2) You want both threads to continue running and processing, thread A writes a value to VAR, thread B is interrupted and gets an event that VAR has changed, and responds. This is a much more complex scenario.
In the case you want scenario 1, (threads that are blocking waiting for a global variable to be set). This is simple and a very common case in multithreading. CVI provides thread safe variables specifically for this purpose. You would create a thread safe variable using the macros defined in CVI. For example, to create and use a thread safe variable, that is an integer called MyCounter. You would do this:
//Before creating the threads, create the variable
DefineThreadSafeScalarVar (int, MyCounter, 0);
/*In each thread, you would access and set the variable through a pointer. This would cause each thread to wait until the pointer had been released by the other thread.*/
int *valuePtr = GetPointerToMyCounter ();
//Insert thread code here to set the variable (*valuePtr)
ReleasePointerToMyCounter ();
//Before shutting down your program, unit the variable
UninitializeMyCounter ();
If you are looking for scenario 2, this is more complicated since it requires events to cause the interrupts of threads that are doing other things. To do this, I wouldn't use one variable, I would use two of CVI's thread safe queues. The thread safe queue provides a built-in callback mechanism, so you wouldn't have to create custom events. There are several examples for programming with thread safe queues under cvi\samples\utility\Threading.
Best Regards,
Chris Matthews
