Hello -
I'm trying to use SetMouseCursor to switch to VAL_HOUR_GLASS_CURSOR during a file processing operation that takes a few seconds. For some reason, the cursor appearance never changes from the default cursor. The operation is initiated by a button "commit" event, and the callback looks something like this:
int CVICALLBACK buttonCallback (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
SetMouseCursor(VAL_HOUR_GLASS_CURSOR);
// Do the file processing here...
SetMouseCursor(VAL_DEFAULT_CURSOR);
break;
return 0;
I've also tried using SetPanelAttribute(panel, ATTR_MOUSE_CURSOR, ...) with the same results. The callback definitely executes, as the file processing works as expected - I just don't see the cursor change for some reason.
I'm using LabWindows CVI 2012 SP1, running under Windows 7. Thanks in advance!
Barry Wealand
