LabWindows/CVI
SetCtrlVal() with textbox - function does not work as intended?
I use this command to update a textbox with a timer:
SetCtrlVal   (MyPanel,  MyPanel_MyTextBox,  SomeText);
It keeps adding 'SomeText' into MyTextBox instead of setting it with that value.  It only works as I want when I use:
ResetTextBox   (MyPanel,  MyPanel_MyTextBox,  SomeText);
Is this supposed to be the way SetCtrlVal() work, because that is how I understand it?
(4,523 Views)
Accepted by topic author hn_sofec
Yes, this is the way it is expected to work... as you can see from the help on "Programming with Text Box Controls", SetCtrlVal appends text
(4,521 Views)
Thanks, I think it is a misnomer.  Should be called AppendCtrlVal().
(4,519 Views)
