LabWindows/CVI
Sending message to secondary thread to quit
I have 2 buttons on my main panel. Pressing one, I start a secondary thread,
using CmtScheduleThreadPoolFunction function. The secondary thread is just
calling Wait, where Wait is:
void Wait(double NumOfSeconds)
double t0;
double t1;
t0 = Timer();
t1 = Timer();
while ((t1-t0) < NumOfSeconds) {
ProcessSystemEvents();
t1 = Timer();
Now when I press the second button on Main GUI, I want to stop this
secondary thread. I know I can use global valiables which I can set in main
thread and check oftne in secondary thread, but I am looking for doing by
sending a message to the secondary thread. So I tried
PostDeferredCallToThread funtion, like:
PostDeferredCallToThread(QuitSecondaryThreadFunction, 0,
Secondary_Thread_I
d)
and
void CVICALLBACK QuitSecondaryThreadFunction(void* pFunctionData)
CmtExitThreadPoolThread(1); <------- is this correct,How do I call it from
my secondary thread
When I do that, I see that my secondary thread doesn't process this message.
The secondary thread is calling ProcessSystemEvents while in wait, so it
should process the message, isn't it?
I am just starting in this so any help is appreciated.
vishi
(3,355 Views)
Hi Vishi,
As I look at your code, the problem might come from the secondary_thread_id. You are using the thread function ID which is different from the thread ID. You need to obtain the thread ID as follows:
CmtGetThreadPoolFunctionAttribute (poolHandle, secondary_thread_id, ATTR_TP_FUNCTION_THREAD_ID, &threadID);
Then use the threadID to call
PostDeferredCallToThread(QuitSecondayThreadFunction, 0, threadID);
This will work (it did for me).
Good luck,
Azucena
(3,355 Views)
Thanks for pointing the mistake. I tried it but still running into problems.
I will look more into it.
vishi
"aperez" wrote in message
news:506500000005000000EDC00000-1031838699000@exchange.ni.com...
> Hi Vishi,
> follows:
> Good luck,
> Azucena
(3,355 Views)
Hello Vishi
I would prefer to use a global variable, check it in the while loop and
return, when the variable is set.
e.g.
volatile BOOL bStopSecond = FALSE;
while ()
if (bStopSecond) return:
To stop the second thread, you only must set the variable to TRUE.
Stephan
"Vishi Anand" schrieb im Newsbeitrag
news:3e16276d@newsgroups....
thread,
> double t0;
> double t1;
> t0 = Timer();
> t1 = Timer();
> whi
> t1 = Timer();
main
> Secondary_Thread_Id)
> and
from
> my secondary thread
message.
> vishi
(3,355 Views)
Thanks, that's what I did and it is working fine.
vishi
"Stephan Gerhards" wrote in message
news:3e1a8d2d@newsgroups....
> Hello Vishi
> e.g.
> while ()
> Stephan
> thread,
just
> > double t0;
> > double t1;
> > t0 = Timer();
> > t1 = Timer();
> > t1 = Timer();
> main
by
> > and
> from
> > my secondary thread
> message.
> > vishi
(3,355 Views)
