This is more of a comment than a question. One thing that I find extremely annoying is the way the search function is implemented in CVI 5.5. When searching for multiple occurrences of a phrase, you cannot scroll through the source code in the area of a search match and/or edit the code unless you exit the search function. Also, I would like to keep "search multiple files" as the default behavior, but the program seems to always revert to single-file searching, requiring another step in the search process.
