11-22-2015 01:36 PM
My name is Haim and I'm mechanical engineering student, who had recently started using CVI.
I have a program called 'XYZ' and all it files including the exe is called the same.
I know there is a way using the save is... to save new uir, c and project files,
But, is there any way to save a new exe file'ZYX' (for example), so that any time i will run the program in CVI (including debugin),
it will generate the new exe?
Thanks in advance
Haim
Solved! Go to Solution.
11-22-2015 01:49 PM - edited 11-22-2015 01:50 PM
The file that is generated when you create an executable takes the name set in Build 》Target settings panel. You can set a different name for each mode (Debug, release and the correspondig 64bit options)l
11-22-2015 02:35 PM
Thanks alot RobertoBozzolo!
11-23-2015 07:53 AM - edited 11-23-2015 07:56 AM
managed to find all except cws.
any idea?
never mind I guess I can just rename it using right click.
