LabWindows/CVI
Saving Converted Bayer Image
Can the NI-IMAQ function imgSessionSaveBufferEx be used to save a decoded Bayer image?  When I try inserting this function call in the BayerDecoding.c sample all it saves is the pre-decoded image.
Message 1 of 14
(3,535 Views)
Hi Matt,
Can you post your edited version of the code so we can see the changes that you made?
Ty Prather
Technical Marketing Specialist
Message 2 of 14
(3,511 Views)
Hi Ty P,
The only changes I made were to add "BayerDecode.h" on line 10 and the imgSessionSaveBufferEx function on line 354
Message 3 of 14
(3,509 Views)
I take that back. The only line I added was 354
Message 4 of 14
(3,509 Views)
Matt,
It definitely seems like the code you added should save the RGB image... Can you tell if the imgPlot2 function on line 358 displays the RGB image or the Bayer image?
Ty Prather
Message 5 of 14
(3,476 Views)
Ty P,
The imgPlot2 function correctly displays the RGB image.  The last field in the imgPlot2 function call is IMGPLOT_COLOR_RGB32 which tells the imgPlot2 function that the pixel depth is 32 bits.  If the field is set to IMGPLOT_MONO_8 then the imgPlot2 function displays the same image as that saved by the imgSessionSaveBufferEx function.  This says to me that the imgSessionSaveBufferEx function is only saving the first 8 bits of a 32 bit per pixel image and I don't know how to tell the imgSessionSaveBufferEx function that the pixel depth is 32 bits and not 8.
Message 6 of 14
(3,468 Views)
Matt,
Got it. So it does seem that the image is being decoded, we're just saving it as a monocrome image. Would you say that's correct?
Let me look into that and see what I can find (if we're on the same page).
Ty Prather
Message 7 of 14
(3,464 Views)
Ty P,
Yes that appears to be the case
Message 8 of 14
(3,436 Views)
Matt,
The ..SaveBufferEx function uses the information from the current session to tell which settings to save with. So I believe we need to be looking at the settings associated with that.
http://zone.ni.com/reference/en-XX/help/370161G-01/imaqfr/imgsessionsavebufferex/
The first one that caught my eye was on line 47. When we're defining our RGBBuffer, we're defining it as an Int8. Can you try changing this to an Int32 and running it?
Ty Prather
Message 9 of 14
(3,430 Views)
Ty P,
Yes that was one of the first things that caught my eye too and I changed it to Int32, but the result was the same.  Line 292 creates the buffer size of 4 bytes per pixel and line 294 creates the RGBBuffer with this size.  My thinking is the buffer size for RGBBuffer must be correct or imgPlot2 would not work.
Message 10 of 14
(3,412 Views)
