11-29-2012 08:01 AM
Occasionally, I want to archive records from 1 database to another. No change in tables or fields, just copy.
Basically, I
Create Record (db2)
Fetch Next until EOF (db1)
PutRecord (db2)
This works, but it is incredibly slow. Any suggestions would be appreciated. I will post code later today.
Thanks in advance, Dave
11-30-2012 01:53 PM
Hi Diverdke,
From what you have described this seems like the most efficient way to move that data. Do the records contain a lot of data? Or does the database have any scheme to keep records in a certain order? There are many factors that may influence performance and those could be hardware or software related. As I said previously the steps you are taking to move the record, in my mind, is the most efficient and straightforward way.
