LabWindows/CVI
SLD overwriting
I'm trying to generate a function panel using the 'generate function tree' option.  I need two SLD (slider) bars, but seems to only take the last SLD defined.
The snippet below will correctly show the SLD with the correct FmtWinOpt enums
   ///HIPAR 7/Format with which to evaluate the passed in value
   ///SLD 7/FmtWinOpt
but if I change it to
///SLD 7/FmtWinOpt
///HIPAR 8/resolution to be used when printing the number to the screen
///SLD 8/Precision
 The slider for parameter 7 no longer shows (though the help is still correct) and now I have a slider for parameter 8 showing correctly.
Is there's something I'm missing or am I only allowed 1 slider per function?
(4,115 Views)
Accepted by topic author MarksAlias
Hello Mark!
I'm afraid that the behaviour you are seeing appears to be a bug in the CVI function tree generation mechanism and that there is currently no workaround for this issue (you can track the bug in the future with ID #456464).
The only way you could correct the behaviour is manually replacing the ring controls with slider controls in the generates function panel.
Thank you and sorry for the inconvenience!
- Johannes
(4,058 Views)
Thank you for the response Johannes!
Always good to know it's not me doing something not smart (for a change).
(4,049 Views)
Hello Mark,
It appears that this behaviour is actually not a bug.
According to this help topic:
This tag applies only to the function immediately following the tag. Do not include multiple instances of this tag for a function. If you do so, the last instance overrides the previous instances.
So in order to have the sliders generated correctly you should put all controls in one SLD tag like below:
///SLD 7/FmtWinOpt,8/Precision
This also applies to other tags.
Constantin
(3,958 Views)
Much obliged Constantin!  Had no idea you could chain the tags like that.  Beats having to add it manually each time!
(3,949 Views)
