Thanks Bilal,
I beleive it will be much simplier if I describe what I want to do in
my project: TestSTan is executing several steps all of which are
doing some action on RS232 com1. I would like to open a 'window'
showing all the action going on on the port (created by CVI), at the
beginning of the steps (in the setup portion), and closed this window
only after the last step is executed.
As of now, I call this window in the beginning of each step and close
it when the step ends. I would like to eliminate this behavior of the
UI comming and going...
How can it be done?
Rafi
p.s. Using TestSTand 2.0+CVI 5.5
