LabWindows/CVI
Reuse a key after activate the wrong alnguage pack
I have installed the english language pack and activated it.
after i realized my fault i deactivated and deinstalled it.
i installed the german language pack. but know there is a problem.
when i want to activate this version there is an error. is it possible to use this key for the german version or can i only use this key for the english version?
(3,879 Views)
Hi Jerome,
You can install your software in any languages with a license.
What error message do you get when you try to activate the software? Also, which colour are the squares in the NI-license manager?
Marc
(3,838 Views)
Hi MarcOesterle,
the problem is as good as solved. The student version is a bit different to the standard version. I will use the english one.
Thanks alot.
(3,834 Views)
