10-31-2013 08:55 AM
Hello togehter,
I'm currently searching for a way to distribute my actual CVI project to a remote system (Windows PC with CVI Runtime) over network and then
start remote debugging automaticaly. The Parameters (IP, port ...) should be configured first. But after that it should be a one click action like pressing the green "play" arrow.
Is there a known way to achive this?
Otherwise I will try to add this missing feature to CVI with external tools. For example adding some scripts to Post-build Actions:
Normal CVI
- Click Run + Debug
- Compile
Post-build Actions
- Create Distribution
- Copy Package to System and execute in Silent Mode
- Copy ConfigureRemoteDebugging.exe to Reomote Client, execute and configure IP and port
Normal CVI
- Start remote debugging and waiting for remote debug application
Special Actions
- Start target application on remote client
Best Regards,
JoMuck
11-04-2013 04:54 AM
Hi JoMuck,
It is important to know which CVI version you are using. You need the Internet toolkit, which was last released for version 7.1. After that we included the Internet Toolkit as the Internet Library in CVI 8 but it does not have the webserver functions which allowed creation of remote user
interfaces. That means you can do remote viewing and controlling of a front panel in LabWindows/CVI 7.1 and earlier versions if you have the Internet Toolkit
installed.
Best regards
