02-22-2015 09:28 AM
I consider the following a bug:
CVI is fairly well done in respect to .prj and .cws files in the sense that if you move a project directory, it adjusts all relative paths without complaining (while leaving alone the absolute paths which are outside of the project tree).
But that doesn't work with .cds (distribution) files. It makes putting a cds file under version control fairly useless as you need to edit the file with a text editor to adjust the paths each time. This should be fixed.
Thanks.
02-23-2015 05:31 PM
Hello gdargaud,
You can make official product suggestions by navigating to the following link:
Product Suggestion Center
http://digital.ni.com/applications/psc.nsf/default?OpenForm
Best wishes!
