I use a source code generator that creates c-code (i.e. hello.c) from some kind of definition file.
I want the generator to create hello.c on each build, so i have decided to put a batch (that calls the generator) into the "custom build step" of my project.
This way the generator is called before each build.
Unfortunatly CVI does not reload the changed hello.c after it has been modified/overwritten by the batch... the build is done with the previous version of hello.c. Not until the build is finished CVI recognizes that hello.c has been modified and prompts "Update Window from Disk", then I have to run a second build in order to get the changes of hello.c applied.
How can I accomplish to have only build process that first calls the generator and then compiles the project (with modified hello.c)?
