01-16-2017 05:41 AM
I have a strcuture of following form.
typedef struct DaqData
int stopFlag;
char Data[]
int readingData;
int panel;
int threadInited;
} AIData;
I would like to create a thread safe queue with the above structure. However the element "Data[]" in the above structure can have varying length and is not fixed size. So, is it feasible to create a threadsafe queue with the above structure. If not , what could be an alternative way to imlement the same.?
Best Regards
Deepu Jacob
Solved! Go to Solution.
01-16-2017 06:52 AM
As you can read in the help
If you need to store items of varying size in the thread safe queue, you must either use more than one thread safe queue, store pointers in the queue, or set the size to 1 and treat the queue as a byte stream.
Passing pointers will imply for example to allocate memory in the producer thread, pass the pointer to it (together with the block size) in the queue and free the memory in the consumer thread.
Using the queue as a byte stream implies the data block is passed to the queue as a series of single-byte elements regardless the structure definition; the consumer thread reads the amount of bytes from the queue and rebuilds the structure element from them. Again, the size of the data block must be passed in the queue as well.
01-16-2017 07:10 AM
passing pointers seems to be a good method. But why do we need the block size anyway?
how to combine block size and pointers as queue datatype? a structure consisting of pointer and block size element?
01-16-2017 08:00 AM
Unless your variable data is a null-terminated string, you have no way of knowing how much data you are receiving other than passing the block size to the consumer thread.
01-17-2017 09:05 AM - edited 01-17-2017 09:19 AM
Hi Roberto,
Based on the suggestions, i have created the following code. There is a structure with the name 'Packet' that defines various members. There is a void pointer member named 'Data'. This pointer is implemented keeping in mind that i can use it to point to data of various datatype and different lengths without affecting the actual size of structure. Since the structure's memory size is constant, i think i can use it with thread safe queue.
static CmtTSQHandle PacketQ;
typedef struct Packet
unsigned short PacketType;
unsigned short Param1;
unsigned short Param2;
size_t DataSize; // size of the data buffer
void *Data; //pointer to data
int main()
float64 *Bptr=NULL; //declare a buffer pointer
struct Packet *Mypacket; //declare a pointer to structure of type 'Packet'
//Initailize a queue with size 10 of type Mypacket(i.e Packet)
CmtNewTSQ(10,sizeof(struct Packet),OPT_TSQ_DYNAMIC_SIZE,&PacketQ);
Mypacket = (struct Packet*)malloc(sizeof(struct Packet)); //allocate memory for structure
Mypacket->PacketType = 1; //assign values to structure members.
Mypacket->Param1 = 100;
Mypacket->Param2 = 50;
Mypacket->DataSize = 1000; //no.of elements in databuffer
//dynamically allocate memory for 1000 elements in buffer
if( (Bptr = (float64*)malloc(1000*sizeof(double)))== NULL)
MessagePopup("Error","Not Enough memory");
SinePattern (1000, 10, 0.0, 100.0,Bptr); //generate 1000 samples and place it in buffer
Mypacket->Data = Bptr; //assigning buffer pointer to void pointer in structure
CmtWriteTSQData(PacketQ, Mypacket, 1, TSQ_INFINITE_TIMEOUT, NULL); //Enqueue data to TSqueue
return 0;
Now, i will dequeue the thread safe queue in another thread and get the information from the structure and then release the memory for Mypacket as well as Data. I would like to know whether or not my implementation will work as intended.
01-17-2017 10:10 AM
I never used such a schema but it seems to me that it should work.
I would have used calloc instead of malloc since it automatically adapts to data type and inizializes all elements to zero.
01-17-2017 10:27 AM
calloc for Mypacket or Data?, or for both?
01-17-2017 10:53 AM - edited 01-17-2017 11:04 AM
calloc for Bptr.
I don't think you need dynamical allocation of the structure.
01-20-2017 01:49 AM
It works fine.
Regards
Deepu Jacob
