NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
_trent_
Question about how AmpPhaseSpectrum works
Hi!
I'm using AmpPhaseSpectrum and i was wondering how it works and what i can get from it.
For example, I use SinePattern to create a sine : SinePattern(nb_pts,5,ph1,sine1)
Then if I compute the spectrum what shall i get in the phase chart of AmpPhaseSpectrum?
Knowing that SinePattern computes the sine this way (according to the help browser of LabWindows):
amp*sin(2*pi*i*cycles/nb_pts+pi*phase/180).
Shall I get "phase"? "pi*phase/180"? or "2*pi*i*cycles/nb_pts+pi*phase/180"?
Thanks in advance
_tren_
Member
_trent_
Re : Question about how AmpPhaseSpectrum works
Moreover, if i take amp[k] and ph[k] from the AmpPhaseSpectrum and use the mto generate sinepattern(nb_pts,amp[k],ph[k],k,tab), wouil I have something? Because I've tried this method but nothing appears on the graph when I want to plot tab...
Ideas?
If you want the code I can post it.
Thanks!
Member
_trent_
Ok, I finally post the code. In case of...
void Afficher_Reconstruction(double sig[], double amp[],double ph[])
	int nb_ele, k,i,j;
	double **tab,sine[nb_pts]={0};
	nb_ele=sizeof(amp)/sizeof(amp[0]);
	tab=malloc(nb_ele*sizeof(double));
	for(k=0;k<nb_ele;k++)
			tab[k]=malloc(nb_pts*sizeof(double));
			for(j=0;j<nb_pts;j++)
					tab[k][j]=0.0;
				for(i=0;i<nb_pts;i++)
						SinePattern (nb_pts, amp[k], ph[k], k, tab[k]);
						//SineWave (nb_pts, amp[k],k*1.0/nb_pts, &ph[k], tab[k]);
						sine[i]=sine[i]+tab[k][i];
	PlotWaveform (p_rec, recpanel_graphrecon, sine, nb_pts, VAL_DOUBLE, 1.0, 0.0, 0.0, 1, VAL_THIN_LINE,VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_RED);
	free(tab);
Active Participant
Guillaume_H
[ Edited ]
Thank you for posting your question on National Instruments' Forums.
I'm not sure I really understand what your question is.
What do you want to obtain in the end ? a reconstruction of your initial sine wave using the parameters you get from the AmpPhaseSpectrum function ?
Could you elaborate a little on your issue so that I would be able to help you ?
You can write in french if needed.
Guillaume H.
National Instruments France
>> NIDays 2011, le mardi 8 février au CNIT de Paris La Défense
Member
_trent_
Bonjour,
C'est exactement ça je souhaite calculer le spectre de phase grâce à AmpPhaseSpectrum et donc récuperer deux tableaux : un d'amplitude et un de phase.
Et le problème est : comment faire pour recréer le sinus initial grâce à ces deux tableaux. Le but étant de faire une décomposition harmonique de sgnaux plus complexes et de poouvoir ensuite reconstruire chaque harmonique et en faire la somme pour retoruver le signal originel.
D'où la question : peut-on écrire  SinePattern(nb_pts,amp[k],ph[k],k,sine) pour reconstruire le kième harmonique.
Merci,
_trent_
Member
_trent_
Une petite relance du post
Member
_trent_
Du coup non? personne ne sait?
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
