I'm having problems with accessing table cells.
* First I load a three col, two row table with data. Works fine.
* I then access column 3 of each row and decrypt the value. I update each column 3 with the new value.
Works fine.
* I then attempt to read back the values for each cell in the table.
Problem:
I get error -55 The index passed is out of range.
I use GetTableCellVal for these operations.
Ex:GetTableCellVal (panel,control,MakePoint (1,1),str);
GetTableCellVal (panel,control,MakePoint (2,1),str);
GetTableCellVal (panel,control,MakePoint (3,1),str);
GetTableCellVal (panel,control,MakePoint (1,2),str);
GetTableCellVal (panel,control,MakePoint (2,2),str);
GetTableCellVal (panel,control,MakePoint (3,2),str);
Questio
n: The above calls return error -55. Why does this not work?
