08-28-2014 04:01 PM
If I add controls using either NewCtrl(..) or DuplicateCtrl(..) to an already existing panel that I loaded with LoadPanel(..), is there a way to change the sequence that the controls are cycled through when using the tab key (or to insert the new controls where I want them in the sequence), or will the added controls always be at the end of the sequence? As far as I can tell, there doesn't appear to be a way to do this but I thought I would ask just in case I'm missing something.
Thanks.
Solved! Go to Solution.
08-28-2014 04:46 PM
SetCtrlAttribute (panel_handle, control_id, ATTR_CTRL_TAB_POSITION, tab_order);
08-29-2014 09:07 AM
Thanks Wolfgang, I knew I was missing something obvious!
08-29-2014 09:14 AM
My pleasure.
