09-26-2016 09:25 AM - edited 09-26-2016 09:27 AM
09-26-2016 12:38 PM
The syntax you are using is intended to select more than one channel: the numbers are the initial and final channel in a list of subsequent channels. Thus, writing Dev1\port0\line0:4 means 5 lines are included in the read/write (FWIW writing 4:0 has the same effect). It is redundant but correct write line0:0 meaning a single line, but you could write Dev1\port0\line0 which is simpler.
This is a help page on this subject.
09-26-2016 02:19 PM
09-27-2016 12:16 AM
Hello Fasching_K,
Dev1/port0/line0 and Dev1/port0/line1 is the correct syntax.
09-27-2016 04:08 AM
Thank you 🙂
