If you are running 16 timers and you try to update and process events at a very fast rate (<1s) you will most defenately miss some events. What typical timing do you use and how many concurrent timers are you running and what is the spec of the PC you're doing this on?
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
