Hello
Make sure that you are the administrator of the machine on which you are trying to install the application. Does this happen with every project that tries to distribute datasocket, or is it just this particular project? Also try installing using the standalone datasocket install that you can find in the \cvi\redist folder if you are using CVI 5.5.
Try manually register the nids.dll ,the command should be "regsvr32.exe C:\WINNT\System32\nids.dll"
Also make sure that the target machine has a recent version of Internet Explorer. Try upgrading to 6, and see if that helps. Datasocket has some dependencies with the internet explorer, so having IE 5.5 and above is one of the requirements for datasocket
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
