Aaron, thanks for your reply. As far as I can tell the call to the PrintPanel routine is the same as the one you gave me, except that the last parameter is 0, instead of 1. I tried switching that back and forth in the test code you gave me and it seemed simply to turn on and off the print dialog box as I expected. So, I guess my remaining question is "Is there a way in code to turn off the printing of a single control on a panel, such that the rest of the panel prints--just not that one control--when using the PrintPanel function?" Perhaps related to that question is "Are there any limits, e.g., number of controls on a form or controls in a project, that I might be running up against that m
ight cause this type of behavior?"
