Juan,
thank you for your answer.
Here a more detailed description of my problem:
System:
Windows XP pro SP1,
CVI 7.0 with cvirte.dll 7.0.0.394,
Dual Monitor Display:
Video Adapter
Primary: SAPPHIRE RADEON 9000 ATLANTIS PRO (64 MB),
Secondary: SAPPHIRE RADEON 9000 ATLANTIS PRO - Secondary (64 MB)
Monitor 1 Sony Trinitron E530 21"
Monitor 2 Maxdata Belinea 10 80 20 21"
Windows Display Properties:
Monitor 1 1280 x 1024, 32 bit
Monitor 2 1280 x 1024, 32 bit,
enabled "Extend my desktop onto this monitor."
Both Display Icons are aligned horizontally.
That gives a display of 2560 x 1024.
The problem:
If you use PrintPanel() on a panel. which is completely visible on the primary monitor it will be p
rinted completely.
If the panel is moved e.g. to the bottom so that only the upper half is visible, PrintPanel() will only print the visible upper half. That is ok.
If you move the panel completely to the secondary, in my settings the right monitor, PrintPanel() will produce an empty printout.
If you move the panel to a position, so that parts are visible on the primary and parts on the secondary monitor, only the parts on the primary will be printed.
In other words: The secondary monitor will be dealed by PrintPanel() as if it was NOT visible.
Other functions of the user interface library, e.g. GetPanelDisplayBitmap(),
do not fail on the secondary monitor.
The multi monitor related functions of the user interface library
GetMonitorAttribute(), GetMonitorFromPanel(), ... work well.
The windows screen dump with Alt+PrtSc keys works well either, independend on the panel position.
Regards
Kai
