LabWindows/CVI
Plus/minus box and check box size in Tree control
In order to make the UIRs more readable on high resolution screens (4K) I have added a feature to change the size of the text and label fonts. Unfortunately I did not found a way to change the size of the plus/minus box and the check box in a tree control, see attached picture.
Is there a way to do it?
(2,714 Views)
There is not a way to explicitly change the size of the plus/minus box of the tree control.
However, there is already a feature that may do what you are trying to accomplish. Have you tried the "Resolution Adjustment (%)" panel attribute?
(2,666 Views)
