LabWindows/CVI
PlotWaveForm and AutoPowerSpectrum
I have an input signal (sine wave) of a couple hundred MHz, and I want to get the frequency components using AutoPowerSpectrum. My issue is that when plotting the result of AutoPowerSpectrum, I cannot get the correct frequency using the default parameters. So I use df as xincrement and I get closer to the correct value but still off by a factor of 1000 (and some change). So I guess my question is how can I use xInitial and xIncrement to get the correct frequency values when using AutoPowerSpectrum function.
Thanks.
(3,988 Views)
Why do you use the default parameters? Of which function, PlotWaveform or AutoPowerSpectrum? Did you try dt = 1.0 / sampling_rate?
Could you just show the relevant lines of code?
You may also want to have a look at the example programs, e.g., thd.cws (samples/analysis)
(3,976 Views)
