02-11-2017 08:19 PM
I am facing a problem with picture loading in table cell. Picture is loaded on a button click, when i load first time it looks like image-1, and the next time it loads proper as in image-2.
Reference images are attached.
Thanks and regards
umer
02-12-2017 12:57 AM
Hi Umer,
03-20-2017 10:45 AM
If this is still an issue, you might want to look into those cell's ATTR_FIT_MODE setting. The difference between the two images looks like the difference between VAL_PICT_CENTER and VAL_SIZE_TO_PICTURE.
