12-05-2014 03:46 AM
I have made a function to get list of name in array but i don t to get it out of the function.
See under:
In the main program :
int iAdjustTableRows()
char **szArrayRes;
GetDataFromDB_OneCol ("Group_Instrument","Group_Name",szArrayRes)
Im not abble to retrieve my array of string szArrayRes !!! Why ??
return 0;
Function
int GetDataFromDB_OneCol ( char *szTableName, char *szColuName,char **szArrayResults)
char szValue [50]=""; char szQuery [512]="";
int resCode, iValueStatus =0,numLine=0;
int hmap =0, i=0,u=0;
int hstmt;
//*** Get number of line (record)
// Formating of query
sprintf(szQuery, "SELECT %s FROM %s ",szColuName,szTableName);
// Select statement
hstmt = DBActivateSQL (hdbc, szQuery);
if (hstmt<= DB_SUCCESS) {ShowError(); goto Error;}
// Get Number of Column
numLine = DBNumberOfRecords (hstmt);
resCode = DBDeactivateSQL (hstmt);
if (resCode != DB_SUCCESS) {ShowError(); goto Error;}
//*** Dimension of 2D array of char accrding to number of line
szArrayResults = malloc(sizeof(char*)*numLine);
//memory allocaring for array
for(u = 0; u < numLine; ++u)
szArrayResults[u] = malloc(sizeof(char)*300);
Fmt(szArrayResults[u],"");
//*** Begin map for constructed SQL statement */
hmap = DBBeginMap (hdbc);
if (hmap <= 0) {ShowError(); goto Error;}
// Specify the columns to be selected and the variables where column values will be placed. //
resCode = DBMapColumnToChar (hmap , szColuName, 50, &szValue, &iValueStatus, "");
hstmt = DBActivateMap (hmap, szTableName);
if (hstmt <= 0) {ShowError(); goto Error;}
//*** Fetch Data until end and fill out array of string
while (DBFetchNext (hstmt) == 0) {
if (iValueStatus != DB_NULL_DATA){
Fmt(szArrayResults[i],"%s",szValue);
i++;
At this point the table of string is fill out correctly .
//*** Free Mapping SQL
resCode = DBDeactivateMap(hmap);hmap =0;
//*** Error handling
Error:
if (hmap)
hstmt = 0;
return 0;
12-08-2014 03:08 PM
try
char **szArrayRes;
GetDataFromDB_OneCol ("Group_Instrument","Group_Name", &szArrayRes)
You might want to return a value with the number of strings
Curt
