07-26-2015 12:42 AM
Hi all,
I’m new user of PXIe-5645R RF vector signal transceiver (VST) on CVI 2013 SP2, Windows 7 64-bit for WLAN test. After Rebuild and Run 80211nMeasureEVM example project, a run-time error has occurred in “Debug 80211nMeasureEVM_dbg.exe” of CVI. The message is shown below:
NON-FATAL RUN-TIME ERROR: "80211nMeasureEVM.c", line 174, col 13, thread id 0x00001F4C: Function niRFSA_init: (return value == -200220 [0xfffcf1e4]). Device identifier is invalid.
80211nMeasureEVM.c source code:
/*Open all the RFSA sessions*/
for (i=0; i<numRx; i++)
if(rfsaSession[i] == NULL) /*if the session not already opened*/
GetCtrlVal(gui, rfsaResourceName[i], resourceName);
checkWarn(niRFSA_init(resourceName, VI_TRUE, VI_FALSE, &rfsaSession[i]));
The program stopped on “checkWarn(niRFSA_init(resourceName, VI_TRUE, VI_FALSE, &rfsaSession[i]));”.
In the same “80211nMeasureEVM_dbg.exe” double-click on "File explorer" without the CVI IDE and click [Start] button, the error of message-box is shown below:
-1074130544: IVI: (Hex 0xBFFA1190) The session handle is not valid.
Then I skipped the IVI’s error and click [Start] again, the VST is workable to measure EVM .
My questions are as following:
John
