Hello
Were you able to narrow the problem down to which of the two proragms was causing the problems? What are those programs using. The problems you are seeing would probably be occuring because of something wrong happening in kernel mode. And using DDE should not be doing anything in kernel mode.
If you can provide some more information about what you are doing, perhaps I can help.
Does the same thing also happen if you use the new
nidaq 6.93 driver?
Bilal Durrani
NI
Bilal Durrani
NI
