08-12-2015 11:22 PM
Hello All
Currenlty i am using Message popup for displaying information, but i would like to programe where POP UP should be for certain time & close it should not wait till user acknowledges
Is there any function in CVI can i go ahead and use? or should i desing one for my requirement?
Hussain
08-13-2015 06:16 AM
There isn't in CVI a timed popup. You can replace it with a normal window called with InstallPopup and with a timer inside that fires on the timeout you want. The timer callback can dismiss the popup with a single DiscardPanel.
