11-18-2015 10:30 AM
Hi
I have a button on main GUI, when user click this button, a new window pop up but it's pretty small, how to specify the new
window size?
11-18-2015 10:55 AM
This depends on the type of window... popup panels have a fixed size. If it is a window you have designed you can change your design This can be done in the UI editor or programmatically using the function SetPanelSize ()
11-18-2015 11:41 AM
Thanks for the info.
I set the panel heigh/width is what I want it, but panel is in a window which is not big enough, I can stretch it to make it big,
just wondering is there anyway to make it big enough by default?
