LabWindows/CVI
Non-fatal run-time error, CVI 7.0, two PCI-6527 cards
System info:
- LabWindows CVI 7.0
- Microsoft Windows 2000 Pro
- Two PCI-6527 and four RS232/8-port cards.
- Using the NI Measurement and Automation tools, all cards work fine.
In CVI, I receive a non-fatal run-time error stating that a first chance general protection fault has occurred. This happens after executing the DIG_Out_Line function for the first time. Two of these messages appear. The output does change after clicking "ok" for both messages. All subsequent DIG_Out_Line function calls work fine. I receive no errors when initializing the cards and pass all values via the appropriate variable types (shorts).
Any insight is much appreciated.
Thanks in advance.
Neil
(2,646 Views)
Neil:
Please try running the DO Line Output example that ships with NI-DAQ. It is located here:
C:\Program Files\National Instruments\CVI70\samples\daq\do\DOoneLine.C
Does the problem occur with this example? If not, please take a closer look at your code and compare to this examples' code...
Good Luck!
Sincerely,
Brooks B
(2,646 Views)
Hello Brooks,
I used the code found in DOoneLine.c and I still receive the error message. I am able to suppress the error using the "Run -> Break on" settings in LabWindows but I would prefer not to do that.
Neil D
Test Engineer
(2,646 Views)
