04-20-2014 08:33 PM - edited 04-20-2014 08:35 PM
I've done several projects using LabVIEW and I've also done several using Measurement Studio and C#. I have another coming up that I want to do different.
First off I want to use Linux. Is LabWindows/CVI available for Linux?
Second, I'm either going to use the linux hardware drivers and C++ or I can use CVI. Is there an advantage to one over the other? It almost seems like CVI (ANSI C) is taking a technological step back as opposed to C++.
If I can get the interface to work correctly, I'll use NetBeans with QT for the windowing. Does anyone have any experiance with this?
Does anyone have any experience using NI hardware/software in linux? If so, what route did you take?
At this point I just want to use Linux. I still may end up using Windows. But if I do I still want to use C++ (or C if I have to).
04-29-2014 02:58 PM
