I am trying to connect ITC503 �Intelligent???� temperature controller.
It is expecting an End-of-String (EOS) character, and the carriage-return is the EOS character. I don�t have any manual, but I am peaty sure that I have set correct correctly set the EOS character to carriage return in the GPIB ibdev function, or at list I made a lot of efforts to initialise correctly the GPIB interface. Any way I cannot connect at all to device, and when I use the LabView drivers Its works without problems. But I need to use LabWindows instead the LV. I need a code on ibdev function to correctly initialse the GPIB interface. It seems that the ITC503 is not a standard GPIB device. I am seriously in doubt whether the ITC should really called so, and not only T
C!
Please Help!
Nikolai
