LabWindows/CVI
NICAN sample programs in LabWindows
I am just getting started with CAN programming in LabWindows CVI. At this time I do not have a CAN card or adaptor on my PC. My company is developing a remote device that will have the ability to communicate over the CAN network thru the PC. I will be adding to a program written in LabWindows to send CAN messages asking for data from the remote device.
I am looking at the Timestamped Input sample program, it says that
"The default ChannelList uses channels from the example.ncd file, located in
\Program Files\National Instruments\NI-CAN.  You can load example.ncd into MAX and
use the default, or specify the channel list of your choice. "
I have loaded example.ncd into Measurement and Automation Explorer. When I run the sample program I get error -1074388725. No explanation is given as to what this error means.
Can anyone suggest a sample program to learn about message send and recieve, the examples dont seem to be helpful to me.
(3,268 Views)
Regards
Krista S.
Applications Engineering
(3,245 Views)
I have exactly the same problem. Also I agree that there could be simpler softwre to send and receive.
Could someone please like answer his post, versus simply ignoring it as already posted. I would like to aee the answer myself.
(2,771 Views)
Nolan,
The error described in the previous post states "The language interface for NI-CAN cannot find a required function in NICAN.DLL. Solution: Uninstall NI-CAN and reinstall." I was able to find this information at the following page.
With that said, if you would like more help with this problem I would suggest starting a new post instead of posting on this thread. This will allow for more exposure to your questions.
(2,748 Views)
