Actually I'm having few issues with the attempt to generate a SPI similar pattern. So I need to generate a clock with the proper pin(using a pin of port0). For some reason I'm having trouble select and to use the right external Source to generate the clock. Do you have any Suggestions to solve the problem? Docs, example 🙂
Thanks.
