03-03-2017 12:18 PM
Hello everyone,
I have a NI USB-8452 SPI device, and the hardware and software manual states that the supported clock rates for SPI for this device are:
48 kHz, 50 kHz, 60 kHz, 75 kHz, 80 kHz, 96 kHz, 100 kHz, 120 kHz, 125 kHz, 150 kHz, 160 kHz, 200 kHz, 240 kHz, 250 kHz, 300 kHz, 375 kHz, 400 kHz, 480 kHz, 500 kHz, 600 kHz, 750 kHz, 800 kHz, 1 MHz, 1.2 MHz, 1.5 MHz, 2 MHz, 2.4 MHz, 3 MHz, 4 MHz, 6 MHz, 12 MHz
However if I use ni845xSpiConfigurationSetClockRate to set the clock rate to 1 (meaning 1 KHz) there is no error. If I retrieve the current clock rate with ni845xSpiConfigurationGetClockRate it confirms that the current clock rate is 1 KHz.
Even weirder is that if I set the clock rate to 48 (which the manual says that the board supports), I get an error:
"The passed-in clock rate was lowered to a clock rate value that the hardware supports. Refer to your hardware documentation for supported clock rates."
If I set to 15KHz it gives me the same error. For clock rates of 2, 3, 5, 10, 20, 100 or 1000 KHz it does not complain.
Am I missing something? It seems that the driver behavior does not match what is specified in the manual.
André
03-07-2017 05:15 AM - edited 03-07-2017 05:39 AM
Hello AndreMarques,
Thank you for posting on the NI Forum.
Looking at the datasheet of your product, this is the expected behaviour.
When you look at this documentation: http://www.ni.com/pdf/manuals/371746e.pdf
1- You have, at page 496, the list of Frequencies allowed by the clock of the SPI protocol:
"25 kHz, 32 kHz, 40 kHz, 50 kHz, 80 kHz, 100 kHz, 125 kHz, 160 kHz, 200 kHz, 250 kHz, 400 kHz, 500 kHz, 625 kHz, 800 kHz, 1 MHz, 1.25 MHz, 2.5 MHz, 3.125 MHz, 4 MHz, 5 MHz, 6.25 MHz, 10 MHz, 12.5 MHz, 20 MHz, 25 MHz, 33.33 MHz, 50 MHz"
2- At page 277, it is said that if you don't select a proper clock value, this will send a warning for at least warned the programmer of the change that has been made for him. You can ignore that warning if you want or get the real value by using the GetClockRate VI :
03-24-2017 06:19 AM
Hello Pierre,
sorry for the late reply.
This is my MAX report:
Operating System(OS) Windows 7 Professional OS Version 6.01.7601 OS Info Service Pack 1 Processor Intel(R) Core(TM) i5-2300 CPU @ 2.80GHz / Intel64 Family 6 Model 42 Stepping 7 / GenuineIntel / 2793 MHz Number of Processors 4 Physical Memory 7.91 GB of RAM Drive C:\ 9.17 GB of 111 GB free National Instruments Software: Version: NI-DAQmx Device Driver 16.0.0f0 NI-DAQmx ADE Support 16.0.0 NI-DAQmx MAX Configuration 16.0.0 NI I/O Trace 16.0.0f0 LabVIEW Runtime 2014 SP1 f5 14.0.1 Measurement & Automation Explorer 16.0.0f0 Measurement Studio Visual Studio 2010 Support - See individual versions below. DotNET Common 15.1.40.49152 Common (64-bit) 15.1.40.49152 NI-845x 15.0.0f0 NI-845x Runtime 15.0.0f0 NI PXI Platform Services Configuration 16.0.0f0 NI PXI Platform Services Runtime 16.0.0f0 NI-PAL Software 16.0.0 NI System Configuration 16.0.0f0 NI-VISA 15.0 NI-VISA Runtime 15.0 LabVIEW Runtime 2015 SP1 f3 15.0.1
How can I send you my sample code? I have two tests: in one I try to send data in a loopback configuration, and set the clock rate to 15 KHz and it fails (as expected). If I set the clock rate in this test to 1,2, 5, 10 and 20 for instance it does not complain. It complains with 3,15 and 48 KHz as expected. Worthy of note is that in this loopback (MISO and MOSI connected) test I send three bytes (255 255 255) and I receive:
1 KHz -> 63 255 255
2 KHz -> 15 255 255
10 KHz -> 0 0 255
20 KHz -> 0 0 0
In another test I set each of the 8 slaves with a different clock rates (1,2,3,5,10,15,48,50) and then close. In this test the driver never raises any issue (while none of these rates are valid for this hardware).
Please tell me how I can send you this code.
André
