Hello
I believe the help file found under Start >> Programs >> National Instruments >> NI-DAQ >> NI-DAQmx Help gives a nice overview of the programming model. There are also tons of examples available that demonstrate how to setup the basic functionality for the data acquisition device.
There is a native .NET DAQmx API available for use with C# and VB.NET. You dont need to have Measurement Studio for using this api, just make sure to install support for the .NET languages when running the installer for the driver cd. The help for the .NET api is integrated with the Visual Studio environment itself.
So DAQmx can be used with LabVIEW 7.1, Visual Studio .NET 2003 (7.1), Visual C++ 7.1 ( requires Measurement Studio 7.0 ), CVI 7.0 and ANSI C.
Check out the
NI-DAQ readme for more information.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
