06-07-2013 04:15 AM
Calling .NET assambly throws an exception in Function "CDotNetInvokeGenericMember". I invoked the beamgage automation interface, which properly work with Labview 2012, but not with Labwindows/CVI. Initializing assembly and creating target was OK.
Solved! Go to Solution.
06-10-2013 10:26 AM
Hi raama,
which version of CVI do you use?
in which version of LabVIEW did the assembly call work?
Did you try this sample code?
Best regards
Suse
06-11-2013 01:35 AM
I found the solution by myself. The reason was, some Dll's called by the assembly DLL where not found. I registered only the assembly DLL. The folder of Labview Example was below the assembly folder.
