02-28-2014 09:03 AM
Dear experienced users,
I am using the following software/hardware:
hdbc = DBConnect ("DSN=dvd_collection");
The error message I have is confusing me.
(it is in the attachd png)
I thought it was due to the 64 bit mysql database. That's why I tried the 64 bit build from Labwiondws/CVI. I alsow tried Labview DB tools open connect.vi. It shows me the same error.
Any suggestion is appreciated.
Jimmy
03-01-2014 04:46 AM
Jimmy
I always use connection strings of the form "DSN=datasourcename;UID=database_user_id; PWD=database_user_password".
Where:
datasourcename = The name of the connection defined in the ODBC connection.
database_user_id = One of the user identities created by the database administrator. Obviously the administrator will lock down the permissions appropriate to the task in hand.
database_user_password = The password that identifies database_user_id, again set by the database administrator.
Note that while it is obviously desireable to lock the permissions down as far as possible on the MySQL server, the more you do so, the slower the database will run, because of the way mySQL searches the permissions tables.
03-04-2014 01:29 PM
hi, Steve
I tried as your suggested. Yet the same error message pops out. I don't think it is a connection issue.
The same code works if I use Access database provided by the example code. No issues at all.
thanks,
Jimmy
