Dear Chris,
Thanks for the answer. I will still need your further help. As per my discussions with NI persons, one can access the register of PCI card. I am having register map of PCI E-series board. I confirmed with NI India persons that the same register map will be for NI 6014. Pls comment on this.
Also, if i want to access(read or write) registers of NI 6014, then i should have base address of NI 6014. Kindly let me know if there is any process of obtaining base address of NI 6014 by programming in CVI without NI DAQ.
Else, is NI is providing drivers for NI 6014 in win3.11 OS(as it is for Win9x through NI DAQ).
regards,
Amit Kumar.
