My OS is Windows 2000,and have one CPU .In multithreads programming , I'd like to know how many threads can be used and can achieve the best performance ? Is there a limit for the thread number ?
The total number of threads you can create is based on the resources that your OS makes available for you. Thread scheduling is something the OS takes care of and optimizes for you, and best performance is based on how you setup your application. This is a good article to start with if you are looking into learning more about multi-threading with CVI.
