From your email, it sounds like you have multiple declarations of the same function, once in the header file (.h) and another in the source file (.c). You need to declare it only once. A good programming practice would be to declare it in a header file and define it (implement the function body) in the source file. Then, you can include the header file in any source file so that you can call the function.
Mika Fukuchi
