08-26-2005 11:15 AM
08-30-2005 08:32 AM
modbus over ip should simply be a case of tcp on the appropriate port (think that's 502)
http://www.modbus.org/specs.php
the above link should give you the specs you need. (Agree to the terms and then follow the next link which should take you to here : http://www.modbus.org/docs/Modbus_Messaging_Implementation_Guide_V1_0a.pdf)
The Modbus.org website also has a tcp library you can purchase.
Another useful link is here :
You can always try an activeX control that can handle it instead. I've not tried the ones from the above link, and they're designed for VB, but should drop into cvi ok. No harm in trying.
Hope that helps
Sacha Emery
National Instruments (UK)
02-13-2009 06:02 AM
Does anybody have modbus tcp functions for LabWindows? Can you give them ? This is my e-mail: pi_meson###front.ru. Thnx.
08-05-2013 04:26 PM
Hello all,
I am working on a project that needs to use LabVIEW to run some of the automatic test to a device over Modbus TCP. Does anyone have a sample code that would like to share with me? Please send to my email address at camvong@hotmail.com. I am really appreciated.
Cam
08-06-2013 04:45 AM
If you really need to perform it in LabVIEW you should post this question to the appropriate board. Even better could be to post in the Industrial Communications board.There are several posts in those boards that refer to Modbus over TCP in labVIEW so I'm sure you can have a powerful help there.
10-02-2013 04:27 AM
Gents,
I have used this a couple of years ago. Please see MODBUS over ethernet sample from the MODBUS foundation, that I ported for CVI.
Best regards
01-03-2014 05:08 AM - edited 01-03-2014 05:14 AM
I have an example of MODBUS communication over TCP/IP with Labwindows CVI 2013 (see attachments).
Dr. Amir Nourdine
R&D Engineer
G. Cartier Technologies (France)
01-14-2014 04:13 AM
i Found this example very useful, thank you
11-11-2014 04:40 AM
hi,
were to open the TCP adress?
were to write the "enum" and coil?
is it a single output control
11-12-2014 07:43 AM
When you execute 'modbus.exe' a pop-up dialog box ask you for the TCP-IP adress of your Modbus product.
After validate the TCP-IP adress, a new dialog box opens.
TCP-IP adress of the computer and of the modbus product are dispayed on the bottom of the frame.
In 'send in modbus format' you have to enter your coil adress, value to send, select a function (writeCoils, readCoils, ..) and validate.
Data sent are written in transmit Box.
Response is witten in Receive box
