Hello all, I've been chasing a memory leak all week, and it appear that the call to DAQmxReadAnalogF64 is the issue.
We're using a PCI-MIO-16XE card, Win7, CVI & Vision 2009.
The code works fine all day, but we're attempting 24-7 fatigue tests now, and it bombs after ~22 hours. 😞
I tried my project on a trial verison of CVI 2013, same results. So I scribbled up a simple test to verify, and it does the same thing.
What am I doing wrong here?
Did I find a problem with DAQmx?
Attached should be the 3 files needed to build the test.
Start Windows Task Manager, run the code, and watch the memory ratchet up.
Could someone verify please, I'm losing sleep over this one.
Paul
